Smog pump removal. Leave wires unplugged?
Car: 86 chevy 28 camaro
Engine: 305 tpi
I remove my smop pump and all the equipment to save room under the hood. There were some wires running to the air pump should i just leave them unpluged? Will it throw a engine code? Also a steel air line unhooked now should it be plugged off?
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Re: Smog pump removal. Leave wires unplugged?
Yes. Mine didn't. Yes.
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Is no feedback from AIR system to the ECM so no codes when divertor valves removed
Make the wires safe ; one in each pair is hot with the key on
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
no code for removing the air pump but, if you removed the AIR pump then you are going to be running leaner than 14.7 whenever the ECM is commanding for AIR to be diverted to the exhaust manifolds. This is because the O2mV threshold has been reduced ... but you don't have the extra O2 in the exhaust that would require this change in threshold. So, the INT will subtract fuel to get the O2 voltage within the proper range (which is now 100mV lower).
eightsixseven
Dec 16, 2024 01:50 PM
Ghettobird52
Jul 5, 2024 11:18 PM
