84 trans am fuel gauge problem..
Old Oct 12, 2012 | 07:38 AM
bigschramm's Avatar
Car: 84 Pontiac Trans Am
Engine: 383 small block
Axle/Gears: 373 w detroit locker
Here's the problem, I've recently picked up this trans am that has had a fair amount of work already done to the car about 15 years ago. Well the car has been sitting in storage since then. When I got It we put motor trans in it and realized that the fuel gauge wasnt working.. So when I had the rear of the car jacked up resealing the rear end I figured I would find the wires to the sending unit and try to test it. Well the wires for the sending unit were nowhere to be found???? Not sure bout that, thats what brought me here, I figured I would throw the question out there before I go further. If anyone can help me with the wire routing of the fuel gauge sending unit(starting from the tank).. If its like most of the other G.M. cars than someone has cut them..?? And I will have to pull the tank.. Anyway thanks.
Old Oct 23, 2012 | 06:14 AM
bigschramm's Avatar
Re: 84 trans am fuel gauge problem..
Old Oct 25, 2012 | 05:20 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Cut ! Print It ! That’s A Wrap !
Sure sounds like the PO cut or removed them.
If that’s the case you will have to go thru the motions of replacing the pump, to access the sender.
Originally Posted by bigschramm
is there another way that the wires for the fuel gauge sending unit run, like up into the interior?
They do go thru the interior however they start from the tank therefore if they are not poking out of the tank they cannot connect to the interior.
Happy Racing!
8 Wheels Corner Better Than 4, If You’re On The Outside You Have Fair Warning
Old Oct 25, 2012 | 06:11 PM
Nunazet's Avatar
Car: 1985 Trans Am
Engine: Stock 305 converted to carb
Here is what the wiring looks like on the inside of the car. ('85 TA ) Black Brown and Pink wires run down the drivers side and out to the tank above the hump.
Here is what the pass through looks like from under neath with the rear dropped and the tank removed / sending unit unplugged.
Old Oct 25, 2012 | 06:31 PM
mecham84's Avatar
Car: '84 Trans am ‘86 Iroc
Engine: 305 auto, 305 auto,
Transmission: Automatic
In '84 the wires should go down and back over the side of the tank (driver's side) and through the port behind the driver's side taillight. They should be pink and black with a two pin connector. If they are not there you will need to drop the tank.
Old Nov 7, 2012 | 07:07 AM
bigschramm's Avatar
Thank you so much for your help, I know it might of sounded like a small problem. But you guys responding to my post in the way you did with the picture's was awesome... Again thanks! I will post when fixed, also will post some pics..
Ghettobird52
Jul 5, 2024 11:18 PM
colton_carlson
Mar 8, 2019 12:21 PM
Reddeath210
Oct 6, 2015 08:20 AM
justin57
Aug 20, 2015 07:05 PM
R3500
Aug 17, 2015 12:16 PM
