starting problem.
Old Oct 28, 2012 | 05:32 PM
91camarox's Avatar
Car: 91 camaro rs
Engine: 305 tbi
starting problem.
hi i have a 91 camaro 305 and im running into a starting issue. ive already got my batttery checked and bought a new starter. basically when ever i turn my car over it just clicks once it takes about 10 to 20 clicks then it finally turns over. i have no clue what it could be if autozone is telling me the battery is fine and a bought a new starter. please help
Old Oct 28, 2012 | 06:43 PM
dentalfloss1's Avatar
Car: 1989 Pontiac Firebird
Engine: 305 V8 TBI
Transmission: Automatic
Re: starting problem.
If it's clicking and not turning over at all until about 10 clicks, I would think the problem is still with the starter. Perhaps a bad starter? I have had that happen to me before. If the lights do not dim too much when you turn it over it most likely wouldn't be a battery problem IMHO.
Old Oct 28, 2012 | 07:08 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
ck. ALL battery/power cables/wires . even if they look clean they may not be getting full power through them . wire brush ALL power & ground leads & connections . (disconnect battery first) any that look bad replace/repair . then give a light coat of di-electric grease to all . the grease is a good idea for all elect. connections (bulbs , sockets etc.) . a light coat/film is all thats needed . good luck .
Old Oct 29, 2012 | 04:54 AM
91camarox's Avatar
Car: 91 camaro rs
Engine: 305 tbi
thank you i will try that this week for sure
Old Oct 29, 2012 | 06:54 AM
darrell_43748's Avatar
Car: 1992 camaro rs
Engine: 3.1 v6 MFI
Transmission: 5 speed
Axle/Gears: poss rear end
i have a 92 camaro rs 3.1 v6 tbi. the other day car started missing. with a little backfire from time to time . i run it for 15 miles that way then it runs fine. this morning it tryed to start then died real fast. after 5 attempts it started, but had to keep on the gas pedal. then after a few minutes it will idal. new plugs,wires cap,button,module , fuel pump,coil. anyone help. could it be the choke? need help plz
Old Oct 29, 2012 | 07:01 AM
Car: 1992 camaro rs
Engine: 3.1 v6 MFI
oh yeah by the way i have no codes but the service engine light stays on. used to come on and got out..
Old Oct 29, 2012 | 09:12 AM
obliovionox09's Avatar
Car: 1984 camaro
Engine: 1970 l48 with vortec heads
Transmission: 700-r4 from a diesel
Check to make sure you have the little wire on the S terminal. And make sure your battery is fully charged.
Old Oct 29, 2012 | 04:48 PM
Car: 1992 camaro rs
Engine: 3.1 v6 MFI
its not the battery or the wire.. its like the choke isnt working ..the turns over fine. all the parts i mentioned was put on in the summer. this prob. just started
Old Nov 18, 2012 | 02:04 PM
Car: 1992 camaro rs
Engine: 3.1 v6 MFI
temp. sensor. went to take it loose and plastic was broke. replaced it runs fine now
Old Nov 19, 2012 | 06:30 PM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
SO you mean you turn once to start and just a single click right? Then takes doing that like 10 times and then finally starts right? If so, then the problem is your ignition switch. I went through same thing with mine and even got a new starter. I ended up going to a push button switch instead.
Old Nov 20, 2012 | 07:53 AM
Adam144's Avatar
Well its a common problem. There are several reasons for that issue. I think you should check these thing and you will caught the reason.
1. Dead Battery Power
2. Dirt in spark plug.
3. Fuel injection system
4. Low flow of current in spark wires.
5. Ignition switch problem
92camaroJoe
Jul 29, 2023 07:57 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
justin57
Aug 20, 2015 07:05 PM
92camaroJoe
Aug 13, 2015 06:07 AM
mustangman65_79
Aug 8, 2015 12:07 PM
