can anyone help me please
Old Nov 4, 2012 | 10:55 PM
brad_4291's Avatar
Car: 84 z28
Engine: 305 HO
Transmission: 5 spd
Axle/Gears: 3:73 posi
hi everyone. and thanks in advance for any help you can give me. i just recently purchased an 84 z28 with 305HO 5spd. motor was completely stock. i installed an edelbrock 1406 carb and 2101 intake with no spacer just gasket, a mallory unilite distributor with vac. advance connected to manifold vacuum, and all computer controlled wiring/components removed. it also has accel plugs, msd street fire plug wires, headers and full flowmaster exhaust. i have just rebuilt the carb making sure everything was adjusted properly and clean. right now the initial timing is set to 14*. it is running very rich at idle and not sure if it is while driving. the exhaust smells very rich. what could i need to do. also what do you think the initial timing should be set at and what should total timing be with the vac and mechanical advance. 32* a 3000rpm? sometimes if i rev it high (at a stop) it backfires out the carb. not sure if the initial timing or the total timing is off (have not checked total timing yet w/ the vac and mechanical) could the timing cause it to be running so rich or something w/ the carb. any body's input would be greatly appreciated because other camaros ive installed the edelbrock 1406 on ran fine right out of the box.
Old Nov 5, 2012 | 08:54 AM
MD83Z's Avatar
Re: can anyone help me please
If you could swap out the carb for a known good one and then swap out the distributor for a known good one....you might isolate the problem....I don't know if that possible for you, I have 2 cars with the same vac advance set up and old parts from junk yards.
Old Nov 7, 2012 | 07:58 PM
jtsk's Avatar
Car: 1992 z28 Purple Haze
Engine: 5.7L Tuned Port Injection
Axle/Gears: 3.23 both spinning
12 to 15 degrees advance initial is pretty good. (I think 6 was stock) Probably about 36 degrees total by 2500 rpm or so. Lean out your carb using a vacuum gauge and you might also consider re-jetting it if needed. That should get you performing pretty good.
