Does anyone sell a TPI lower radiator hose???
Old Nov 5, 2012 | 12:44 PM
Black88Z's Avatar
Car: 1988 IROC-Z Camaro, 1981 Trans Am
Engine: 350 TPI, 301 N/A
Transmission: 700r4, 350thm
I just put in a new radiator and when i did i put all new hoses in. The lower hose had a spring/coil in it, and i know tpis had to have it to prevent the hose from pinching shut under throttle. Everywhere I called had the hose, but no spring. And the hose wasnt even the right one, it needed to be 'trimmed" to fit. Does anyone know where i can find one? Or have a part number? I called advance auto and the guy said it didnt need the srping, that they "reinforced" their hoses and they were strong enough without the spring. Well, skeptically I bought one and put it on, apparently the guy doesnt know what hes talking about because it still pinches shut.
Thanks for the help.
Old Nov 5, 2012 | 10:21 PM
majobis's Avatar
Car: 1987 IROC Z w/T-Tops
Transmission: Automatic
Axle/Gears: G92
Re: Does anyone sell a TPI lower radiator hose???
Just last month, I bought one at RockAuto.com. $12 bucks for Delco # 24132L
http://www.rockauto.com/catalog/more...451&cc=1035672
Old Nov 7, 2012 | 07:51 AM
88FormulaF_Bomb's Avatar
Car: 1988 firebird formula 350
Axle/Gears: 2.77
u can probaly find one easy and almost free from a parts car. check ur local craiglist. id give u one if u were close
Posted from Thirdgen.org App for Android
Old Nov 7, 2012 | 09:13 AM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
The spring is used in many lower rad hoses to prevent the hose sucking shut when the t- stat opens. Has nothing to do with TPI or no TPI. The lower hose is common to most all chev V8 cars as the water pump and rad positions are pretty standard. The spring can be removed from the original hose and installed into the new hose. Aftermarket hoses are often cut to length as they fit several applications.
Old Nov 7, 2012 | 02:48 PM
Black88Z's Avatar
Oh ok, i didnt know that.
Majobis, did the one you bought from rockauto have the spring in it? Was it a direct fit or did you have to cut it?
Old Nov 10, 2012 | 10:35 PM
majobis's Avatar
Axle/Gears: G92
I haven't installed it yet, but I just checked it; no spring in the new one. I'm unsure if the currently installed one has a spring. If not, it's never been a problem.
Old Nov 11, 2012 | 12:21 AM
Keoman's Avatar
Car: 1989 IROC & ROLL-Z
Engine: L98 Vortec FIRST TPI
Transmission: T56, Mech Speedo
Axle/Gears: G92 J65 3.27
Just put a new lower on my car. Never had a spring. To tell you the truth, a spring on a hose that flexible, I just can't see it stopping the hose from pinching if there is THAT much of a vortex created by your water pump under acceleration.
What happened to the spring you had on your old hose?
Old Nov 11, 2012 | 04:19 AM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
It's been at least a decade since I replaced my hoses but I'm pretty sure the lower hose didn't have a spring in it.
Here's an interesting read:
http://automotivemileposts.com/autob...dhosecoil.html
Maybe this might work for you and allow you to sleep better at night. Just don't tell anyone you're running Ford resto parts.
http://www.virginiaclassicmustang.co...OCK-P1415.aspx
Old Nov 14, 2012 | 02:47 PM
Troys88GTANotch's Avatar
Car: 1988 Trans Am GTA Notchback
Engine: 350 (CID) 5.7L TPI
Transmission: 700-R4
Axle/Gears: 3.27 Posi
I am in need of a lower hose myself, but unfortunately this part#24132L does not come with the spring in it. I asked them to confirm that it did so they called AC Delco, and AC
Delco said that this part number does not have the spring in it. So it looks like im going to try and find it directly from GM and see if they have one or can special order me one.
Old Nov 21, 2012 | 08:27 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Actually, with 15-16 psi system pressure, no hose in the cooling system is likely to suck shut. At least not for more than a second when the t-stat first opens. Just the same, GM thought the springs were a good idea. I've installed more lower rad hoses than I care to count. Some had springs, some didn't. Never noticed much difference in cooling system function either way.
1992 Trans Am
May 10, 2023 07:19 PM
MantyZ28
16
Dec 21, 2015 11:02 AM
92firebirdchris
Exterior Parts for Sale
Aug 14, 2015 11:56 AM
Firechicken86
Aug 12, 2015 10:07 PM
Sanjay
Aug 12, 2015 03:41 PM
