Stalling
Old Dec 6, 2012 | 08:18 PM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Stalling
My car runs great except for a stalling at a light once and a while. Well it has gotten worse
It seems as though when I come to a stop just after the engine goes into closed loop it will stall. It will idle for a second or two then just cut off. It starts right back up but I give it a little gas while holding the break to be sure it does not stall again.
Question = can I take out the IAC valve and just clean it and the opening then put it back in with out a reset procedure as long as I don't move any thing ?
Old Dec 6, 2012 | 08:25 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Re: Stalling
Yes, you can remove the valve and clean it without adjusting anything. Also clean the hole that the valve seats on while you have it out.
Old Dec 7, 2012 | 06:50 PM
Engine: TBI,5.0
Re: Stalling
Thanks for the reply and answer.
darwinprice
17
Oct 11, 2015 11:51 PM
HoosierinWA
Oct 7, 2015 10:15 AM
Jlanz55
Sep 29, 2015 08:55 AM
lanceflame44
Sep 25, 2015 12:28 PM
amcnellis
Sep 16, 2015 04:16 PM
