new 355 swapped in but no start
Car: 85 camaro
Engine: 5.7
Transmission: th400
Axle/Gears: 4.10
I recently took my 305 out and put in a 355.
I hooked up all my orginal ignition wiring and hope it would start.
I got nothing so my machinist gave me a coil and
A Mallory unilite to put in. I hooked it up and I got nothing.
How do I make it simpler or easier to start up.the motor without
Using all of the cars existing electronics.
It was a 305 carb with hei.
Any ideas?
Any ideas?
Re: new 355 swapped in but no start
Not sure why the car's electronics are a problem here? (since they're most likely not)
Put the car back together like it was; stock carb & ignition system.
Find #1 TDC ON THE COMPRESSION STROKE; keeping in mind there's 2 instances of #1 TDC per engine cycle, one of which is the point that it fires, and the other is the point where the piston reaches the top as the exh valve closes and the int valve opens. Best way to find it is, take out the #1 plug, have your assistant BUMP the starter while you hold your finger over the hole, when you feel compression start watching the timing mark (which no doubt you already verified for accuracy during your build rather than just "assuming" it was right), and leave the engine sitting at about 15° advanced (BTDC); drop in the dist with the star wheel lined up and the rotor pointed at the #1 plug wire.
Then finish assembling the car, give it a coupla shots of gas with the accelerator pump (or just pour an ounce or 2 down the throttle bores), reach in the window, and fire it RIGHT UP.
Car: 85 camaro
Engine: 5.7
Transmission: th400
Axle/Gears: 4.10
Aw I did that 2 days ago with my dad we hooked up everything
And it turned over but no spark. And that's with the stock.hei. then I got the Mallory
Hookrd it up and still nothing. Im getting to the point were im going
To just get rid of it.
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
" Nothing "
As in the motor will not turn over or as in the " not firing "?
Car: 85 camaro
Engine: 5.7
Transmission: th400
Axle/Gears: 4.10
Not firing the motor turns fine.
I want to use the Mallory but I'm starting to think its junk
Car: 1986 Trans Am
Turn your ignition switch on... does the power wire to the distributor have power?
You won't have fire if the dizzy isn't getting any power.
If no power to the dizzy, check your fuses, then wiring, then ignition switch.
Car: '87 Camaro
Pull a spark plug wire & spark plug. Reattach the plug wire to the spark plug.
Lay the sparkplug against a header. Have someone crank the motor.
Watch for spark & see if it dates & what color the spark is.
Yellow is weak blue is good.
theshackle
Mar 5, 2017 06:37 PM
