If I loose my smog pump....
Car: 1990 z28
Engine: 5.0
Transmission: t-5 wc
Axle/Gears: 4th gen 3.42 posi
I have a 350 tbi set up I'm removing the smog stuff (non emission state) willthis affect anything like o2 sensors and computer. also going to re route the heater core hoses . anything I should know before I start yanking that stuff out . I would say my mechanical abilities are a little above average but I've always been one to put things back to factory . not much experience with engine mods. thanks .
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: If I loose my smog pump....
With a 350 tbi Im sure your running a different eprom ? You should max the Air Divert vs Disable Coolant Temp to disable the air pump.This is for $8d you may be running $61 definition but still applies.
https://www.thirdgen.org/forums/diy-...-pump-air.html
https://www.thirdgen.org/serpentine
