Steering Pump Pulley Question
Old Feb 28, 2013 | 07:48 PM
FireDemonSiC's Avatar
Car: 1985 Z28
Engine: 334 Stroker Superram 222/230
Transmission: Full Manual 700R4 / 3k Street Edge
Axle/Gears: 3.90 Eaton, Moser, Richmond & More
I'm going to be overhauling my power steering system once the weather warms up. The only thing I have left to get is a new pulley.
If I have researched things correctly, I will need a .750 shaft diameter pulley with a press fit. The only thing I am unsure of is the outer diameter size.
I have been looking at two pulleys one with a 5.750" outer diameter and one with a 6" outer diameter. If summit's catalog is correct the stock OD is 5.8" My engine has the BBK underdrive setup so which would work best? It should be noted that future plans for this car involve a new engine build that will be spun a little past 6k.
5.750" pulley
http://www.summitracing.com/parts/mch-520
6" pulley
http://www.summitracing.com/parts/bsp-86520/overview/
Stock (5.8") pulley
http://www.summitracing.com/parts/rn...t/model/camaro
I would prefer the march performance since it's powdercoated plus I think the holes in the billet specialties one look fugly.
Frozer!!!
Jan 19, 2024 04:55 PM
evilstuie
Jan 9, 2020 08:29 PM
backtothe80s
Sep 5, 2015 12:39 AM
redmaroz
Aug 16, 2015 11:40 PM
Street Lethal
Aug 12, 2015 11:33 AM
