What pilot bearing do you recommend?
Old Mar 6, 2013 | 08:09 PM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
Just as it says, what pilot bearing do you guys recommend to use for my V8/T5? It won't see a ton of power or anything, so I'm not looking for the most expensive thing in the world, but I don't wanna install something that will burn out in a couple of years. If you have a part number or link, it would be appreciated!
Not sure if it matters, but it will be a V6 T5.
Old Mar 6, 2013 | 08:21 PM
Re: What pilot bearing do you recommend?
The cheap Summit one is fine.
Old Mar 6, 2013 | 11:01 PM
Westech's Avatar
Car: 1991 Camaro RS
Axle/Gears: 7.6" 3.73 yukon locker
I just get the bushing from autozone or what have you. Make sure its all cleaned up and slap a little grease in there call it good. I dont like the bearings I have had a few fall apart and cause trouble.
Old Mar 9, 2013 | 09:51 AM
FNFAL308's Avatar
Car: 91 Bird
Engine: TPI 350
Transmission: 5-Speed
Axle/Gears: 2.77 posi
bushing - not bearing. Never had a bearing hold up like the bushing.
Old Mar 9, 2013 | 01:07 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Yeah I just use the bronze bushing. Most clutches seem to come with one anyway.
F-body-fan
Jan 12, 2023 01:49 PM
gord327
Oct 3, 2015 01:25 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
Zell1luk
Sep 29, 2015 10:36 AM
mfp189
Sep 27, 2015 09:25 AM
