cooling fan not working:(
Old Mar 12, 2013 | 09:10 AM
Jesse85iroc-z28's Avatar
Car: 1985 iroc-z28 camaro w/ 50,000ml
Engine: tpi 305
Transmission: slightly built 700r4
Axle/Gears: stock
so my 85 iroc has been sitting for a few years sleepin and when i went to start getting it ready for the the cooling fan rarly turns on i no its supposed to turn on at 222f or so buts its not when the car reaches it anybody have any ideas on what to check first??
Old Apr 28, 2013 | 08:29 PM
Ingram78's Avatar
Car: 1985 firebird
Engine: 360"sbc NA pump gas
Transmission: Th350 manual valve body
Axle/Gears: Moser 12 bolt 4.11:1
Re: cooling fan not working:(
Relay may be bad. Or if they don't have the proper voltage getting to em the wont turn the fan on, make sure alternator is charging and or battery is good. If it comes on when you jump the battery or put it on charge that should be the prob.
Linson
Oct 24, 2025 02:00 PM
sheachopper
Jul 31, 2019 11:27 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Fanatic1074
Oct 2, 2015 03:47 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
