need help determining if i have a dual bowl master cylinder.
Old Mar 16, 2013 | 03:22 PM
1983Z28Custom's Avatar
Car: 1983 Camaro Z28
Engine: 5.7 liter V8
Transmission: 5 speed manual trans
Hi all this is my fourth posting in a month and i still have not gotten my camaro's brakes fixed. The good news is it finally looks like i found a universal prop valve that will fit my camaro, but the only catch is it will only work with a dual bowl master cylinder.
I cant tell what mine is but i think it is dual bowl. When i take off the cover to add fluid it has a line that goes down the bottom of the cylinder but the fluid still goes over the line so im not sure. My camaro is a 1983 Z28 that originally had a 5.0 H.O. if anyone knows what type of cylinder is in mine please let me know as soon as you can i will greatly appreciate it!
Here is a link to a site that has a picture of what my master cylinder looks like.
http://www.classicindustries.com/cam...s/mc39385.html
Old Mar 16, 2013 | 05:57 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: need help determining if i have a dual bowl master cylinder.
The reservoir design makes it confusing but all master cylinders since around the mid 1960's have been a dual circuit master cylinder. The front section of the reservoir is always larger because it feeds the front brakes of a front disk brake system. With a 4 wheel disk brake system, both sides of the reservoir are normally the same size.
Old Mar 17, 2013 | 06:49 AM
Thank you so much for the information,you have no idea how appreciative i am for that! I am going to order that prop valve now, and ill finally have my Z28 back on the road soon!
jaridjohn
Oct 5, 2015 07:01 AM
zman1969
Oct 1, 2015 11:09 AM
