Will switching to vac advance distributor mess up converter lock up?
Old Mar 30, 2013 | 08:44 PM
Jeremy71504's Avatar
Car: 86 TA, 04 mazda 3
Engine: Just rebuilt 350
Im in the process of swapping in a 350 in my 86 TA on some what of a budget. My original CC distributor was broken during removal of the old engine and I was able to pick up a vacuum advance distributor on cheap and wanting to use it. I keep reading if you use a vacuum advance distributor you lose your torque convert lock-up but that's with a carb swap as well but im using the original intake and carb from the 305. Will I lose converter lock up with this distributor?
The engine is still on the stand so im trying to get everything straightened out before i drop the engine in a few weeks. Thanks for the help, this site has helped my greatly with my new project car!
Old Mar 30, 2013 | 11:26 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Will switching to vac advance distributor mess up converter lock up?
I keep reading if you use a vacm advance distributor you lose your torque convert lock-up but that's with a carb swap as well
I suspect if you don't have a CC dist then you no longer have a computer controlled engine ( same as a non CC carb swap ) because the computer relies on inputs from the CC dist
Old Mar 31, 2013 | 10:23 PM
OK thanks for the help, I figured that would be the issue but i couldn't find a definite answer on the matter. I ordered a re manufactured CC distributor from classic industries for $120 so I wont lose torque converter lock-up.
Old Apr 1, 2013 | 12:38 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
There are several ways of controlling lockup without a computer like the early non CC carb cars did
https://www.thirdgen.org/forums/carb...c-control.html
Old Apr 3, 2013 | 10:34 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
But putting a computer distributor back in is the right thing to do if the computer carb is going to be used.
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
355sbcTPI
Aug 19, 2015 04:38 PM
86IROC112
Aug 17, 2015 02:00 PM
midias
Aug 15, 2015 05:07 PM
