motor bobs when in high rpms, help?
Old Apr 3, 2013 | 12:13 AM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
I'm having a problem when I get on the gas on my Car when its in 3rd gear the motor "bobs" or fluctuates like its running out of fuel, if I start to ease out of the peddle the motor will start yo accelerate a little more than will start to Bob again.does this sound like a fuel issue? I was thinking it could be a clogged fuel filter or clapsing rubber fuel line going from my regulator to my carb. Help or suggestions? I'm still tunning the in tank pump going to a Mallory 3 port adjustable regulator then to my carter afb carb
Old Apr 3, 2013 | 04:10 AM
Redchevy808's Avatar
Car: 1992 camaro rs
Engine: 92 350ci carbed
Transmission: 700r
Axle/Gears: Stock 10 bolt 2:73 gears 😭
Re: motor bobs when in high rpms, help?
Sounds like you don't have enough fuel pressure, you got a regulator?
Old Apr 3, 2013 | 08:20 AM
Engine: L31 350
Yes Mallory 3 port style.
Old Apr 4, 2013 | 12:12 PM
spray004's Avatar
Car: 1991 Camaro RS
Engine: 355
Transmission: BTO 700R4
Axle/Gears: 4th gen 3.73
Sounds like running out of fuel. Adjust your pressure while the car is running. What do you have the pressure set to?
Old Apr 4, 2013 | 12:37 PM
Engine: L31 350
I don't have a gauge installed yet, I'm running a Mallory 4309 return style regulator. I posted in can other forum about it trying to figure out which way I should adjust it to adjust the pressure
eightsixseven
Dec 16, 2024 01:50 PM
theshackle
Sep 17, 2020 08:26 AM
forstral
Aug 19, 2015 03:20 PM
TA8487
Aug 16, 2015 12:21 PM
