Easy serpentine belt set up.
Old Apr 3, 2013 | 08:20 PM
Shiozaki's Avatar
Car: 87' Camaro RS.
Engine: .030 over 71' 307
Transmission: t-5
So right now my car has the old belt style, got like 4 belts, so i want to got to one belt, can i buy all the stock pulleys? or would i be better of pulling what i need out the junk yard, any affordable aftermarket kits?
Old Apr 3, 2013 | 09:19 PM
Rolling Thunder's Avatar
Car: 86 T/A, 83 Z/28
Engine: 5.0 TPI, 350 2 X 4 bbl
Transmission: 4 speed auto, 5 speed manual
Axle/Gears: 3.23 posi, 3.73 std
Re: Easy serpentine belt set up.
Junk yard. Its not just the pulleys that are different all the brackets are different as well as a reverse flow water pump.
Old Apr 4, 2013 | 04:48 AM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
One belt sepentine is a nice setup. You can buy a kit from GM - comes with absolutely everything to do the swap, but it's expensive.
Junkyard would be the ideal source, just make sure you get everything, including all the smaller stabilizing brackets on the intake and exhaust manifolds.
Old Apr 4, 2013 | 06:55 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
The following may provide some useful info about the conversion:
https://www.thirdgen.org/forums/afte...rsion-kit.html
JamesC
Old Apr 5, 2013 | 04:07 PM
Shiozaki's Avatar
Car: 87' Camaro RS.
Transmission: t-5
Looked at that link, so is it just me or dose 700 seem like alot? would the parts off a 4.3 work? hmm
1992 Trans Am
May 10, 2023 07:19 PM
lakeffect2
Aug 23, 2015 08:44 AM
mustangdmurder
Aug 21, 2015 07:17 PM
89lsc
Aug 14, 2015 04:58 PM
jahblah
Aug 12, 2015 05:54 PM
