need some help asap!
Old Apr 8, 2013 | 04:25 PM
hardroc's Avatar
just installed ez-tcu everything is hooked up. but the car just wants to idle a little high then choke out plus it seems to be loading up. the only thing i have unhooked is the speedo and the tcc plug for the 700 r4. the car is 88 iroc 5.7l
do i need to hook the speedo output wire from the tcu to the ecm ? i can only program it down to 4000ppm. if i hook it before the buffer will it covert it to a useable signal? any help i appreciate !
Old Apr 8, 2013 | 07:34 PM
hardroc's Avatar
Re: need some help asap!
ok well i got that figured out i had pulled the vacuum off the intake. thanks
92GTA
Apr 9, 2016 07:39 AM
86White_T/A305
Mar 6, 2016 01:48 PM
Brother Al
Oct 14, 2015 06:39 AM
92projectcamaro
Sep 24, 2015 08:09 AM
NastyEngines
Group Purchases
Sep 8, 2015 10:14 AM
