fuel Pump replacement question
Old Apr 13, 2013 | 02:11 PM
slauter33's Avatar
so my fuel Pump went out and i found this one http://pages.ebay.com/motors/link/?n...204124....will it work or should i just buy a new one from autozone? thanks in advance
Posted from Thirdgen.org App for Android
Old Apr 13, 2013 | 02:18 PM
proj88formula's Avatar
Car: formula
Engine: 305 tbi
Axle/Gears: Ls1 3:42
Re: fuel Pump replacement question
your link wont pull up for some reason. i bought my pump from car quest. mine is for the tpi H.O. so i dont know if they are comparable. are you using the old sending unit or a new one? i bought a whole new sending unit and with the sending unit being aftermarket i had to modify the bottom plate a little for it to fit. that all being said everything went together quite nicely. just when i hooked it back up and tried to start it i got nothing from the pump. so im going to have to take it all apart and see what went wrong. just double and triple check your work. this stuff is a nightmare. best of luck.
Old Apr 13, 2013 | 04:23 PM
Martinez115's Avatar
Car: 1989 GTA
No idea.
I have a 1989 Pontiac trans am GTA
I replaced the sending unit, strainer, and the pump. I got the pump at auto zone and worked fine $55 but well see if it holds up for a long time. And third gen ranch has a used sending unit for sale as well.
http://www.thirdgenranch.com/82-92-c...-fuel-injected
Link won't open up on my end either.
Frozer!!!
Jan 19, 2024 04:55 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
justin57
Aug 20, 2015 07:05 PM
Kaweh
Aug 9, 2015 02:54 PM
