MSD Ignition Box Locaton
Old Apr 21, 2013 | 01:06 PM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Just picked up an MSD Digital 6-plus box.
I'm trying to see if I can hide the box and was wondering where is the best place to install so the box is not visible in the engine bay.
Inside the car? Under the battery tray?
Need advise.
Also have the MSD coil and wiring harness.
Old Apr 23, 2013 | 01:08 PM
Car: 89 IROC
Re: MSD Ignition Box Locaton
anyone?
Old Apr 23, 2013 | 01:34 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
i mounted a couple of amps about the size of an MSD 6 under my drivers seat;cut out the carpet under the esat and made a mount plate for the amps.I don't know if having the MSD box in the car interior would cause interference with the radio.
Old Apr 23, 2013 | 03:59 PM
Password's Avatar
Car: 1992 Camaro RS
Engine: 3.1l MPFI v6
Transmission: 4spd auto w/ overdrive
i wouldnt hide it, they usually dont look bad. I would suggest that you just mount it on the firewall next to the distributor.
Old Apr 23, 2013 | 05:12 PM
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
You want it close to the distributer and battery power source.
Also want it away from water, so I would not suggest under battery tray.
Painting it semi flat black would help it blend in well.
Hotrodboba400
Dec 10, 2019 07:07 PM
86CamaroDan
Sep 29, 2015 10:08 PM
TrevinE
Sep 14, 2015 03:20 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
