What to do
Old Apr 29, 2013 | 07:44 AM
Kornis's Avatar
Car: 1986 IROC Z28 Camaro
Engine: 305 4BBL
Transmission: 5 speed Manual
Axle/Gears: 373 Limited Slip
What to do
I have a 1986 IROC Z28 - 305 4bbl, 5 speed manual and 373 limited slip rear. When I first got the car, it would not run and had to fix the timing on it. The car runs ok, but when I floor it at low RPMS, it tends to bog down. Seems that the carb is working ok, once, I get some RPMS in it, I can floor the gas pedal with no issues. The Distributor has been suspect since I got the car. Can I replace the ditributor with a non ECM controlled vacumm advance with out replacing the intake and CARB. That will be my next purchase besides exhaust. I am trying to keep the mods to a minimun since I am working on getting a 350 and completely redoing it( or just get a 350 crate). Not sure which way I wanna go yet. I do not need to worry about emissions so that not my concern. I tagged it as a classic and strickly keeping it for a weekend hot rodder type play toy.
Old Apr 29, 2013 | 09:18 AM
zraffz's Avatar
Car: 1994 Z28
Engine: 355 LT1
Re: What to do
An HEI should work fine. You can get one from Jegs for like $90-130.
Old Apr 29, 2013 | 01:06 PM
LarryD's Avatar
Car: 92 RS
Engine: 3.1 V6
Re: What to do
Have you checked the lash in the carb linkage? Make sure the throttle valves are opening at the right time. I had a carb engine doing that years ago and it was the set up in the linkage between the primary and secondary...
