knocking at WOT
Old May 8, 2013 | 10:25 PM
EvelBist's Avatar
Car: 89 Black GTA
Engine: 'close to' stock 5.7 but trending>>
Transmission: 700
knocking at WOT
89 L98, 700R4 basically stock.
Running a Tech1 in Data List mode, I can watch the KnockTiming and KnockSense parms. BLM 127, Int 128, pretty darn good. ClosedLoop.
When accelerating smoothly without stomping on it onto the freeway, no knocking reported and the trans doesnt kickdown.
Stomping on it with the trans kicking down, knock retard of up to 12 with large vibration in the dash. It only does this while the trans is in kickdown mode. As soon as I let off the gas to let the trans "relax" back into normal mode, the knocking goes away?
Old May 8, 2013 | 10:55 PM
bygddy's Avatar
Re: knocking at WOT
Trans problem, converter or other that's being transmitted as "knock" to the ecu. Woulda said garbage gas and carbon build up with a mostly stock L98 but the vib through the dash says trans issue.
Old May 8, 2013 | 11:02 PM
EvelBist's Avatar
Car: 89 Black GTA
Transmission: 700
Re: knocking at WOT
ok. Maybe flexplate or converter?
Pac J
May 17, 2020 10:44 AM
RedLeader289
May 28, 2019 01:47 PM
bigjay89gta
Oct 15, 2015 08:04 AM
efiguy
Sep 27, 2015 01:30 PM
Damon
Sep 26, 2015 04:29 PM
