Serpentine belt system difference???
Old May 19, 2013 | 10:02 PM
cdartz's Avatar
It's been a while since I've checked in here, so I don't know if anyone even remembers me, but I'm an old member from back in the day. I still have one of my thirgens, and recently ran into an issue that peaked my curiosity.
Ok so the car is a 1990 Camaro RS. It originally came with an L05 TBI 305. About 11 or 12 years ago with the help of two friends I put in an L98 350 TPI from a 1988 GTA. At this point some of the details of the swap are a bit hazy, and admitedly I was not the brains of the operation. In fact I was only present for maybe 75% of the work, so while I certainly got my hands dirty I can't claim to know everything that transpired.
I drove the car for a year or two tops, and then it sat, and sat, and sat for about 8 years total. In 2011 I put it back on the road, and while it needed quite a bit of work to get it running again I did not replace the serpentine belt at that time.
Now if you are still with me we have reached the point of this post. I have no idea what parts of the serpentine belt system are from the donor car, or what parts are original to my car. As far as I knew all 88-92 serpentine systems were the same, but apparently they are not. I purchased a new belt a few days ago for a 90 Camaro that was 94.5 inches long. Unfortunately the old belt on the car proved to be 98 inches. I headed back to the auto parts store, and they looked up a 1988 model, which did in fact call for a 98 inch belt. So apparently while a 90 F-body takes a 94.5 inch belt, an '88 takes the longer 98 inch belt.
So does anyone know what might be different between these two years? My best guess is a difference size pulley, maybe on the power steering pump?
Old May 19, 2013 | 10:10 PM
zraffz's Avatar
Car: 1994 Z28
Engine: 355 LT1
Re: Serpentine belt system difference???
Couldn't tell you the difference but it probably is a pulley. I'd almost want to say on a motor swap it would probably be the crank pulley but who knows for sure. A difference in 4" sounds a bit excessive for any pulley.
As long as you know your car takes a 98" belt and you can bring in any (future) broken accessories to the auto parts store it shouldn't matter.
Old May 19, 2013 | 10:56 PM
cdartz's Avatar
Oh I'm not worried about it. It's just more curiosity than anything. You might be right about the crank pulley. We probably didn't swap that out. That makes a lot of sense.
1992 Trans Am
May 10, 2023 07:19 PM
zayne0
Aug 24, 2015 07:22 PM
mustangdmurder
Aug 21, 2015 07:17 PM
jahblah
Aug 12, 2015 05:54 PM
scottmoyer
Interior Parts Wanted
Aug 9, 2015 10:18 PM
