Code 54 - TPI - Fuel Pump Circuit
Old May 20, 2013 | 04:12 PM
Dennis-Z28's Avatar
Car: 1991 Z28 Convertible
Transmission: 5-speed
Axle/Gears: 10 bolt, 3.08
I am getting code 54 lately with a long startup. I have the GM service manual for my 1991 and went through the diagnostic tree for the trouble code; using check engine light and a fused jumper. I came up with needing a new fuel pump relay. I unplugged it and tested it a bit and then re-plugged it into the car and now my car works again with a 2sec fuel pump priming with ignition ON.
Should I still replace the relay? Can they be intermittent or am I now realizing it may be a loose connection or wire somewhere??
Grant2k
Jul 10, 2018 04:01 PM
Jae992
Aug 27, 2015 09:07 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
