What is the block code for tpi 350 block
Old May 21, 2013 | 09:46 AM
M3638's Avatar
Car: 1990 Iroc Convertible
Hello, I'm new to the site. I have a 1990 Iroc conv 305 auto. I'm looking at buying a 5.7 tpi engine from a guy. What and where should I look on the block that would tell me it's a 5.7? Thanks
Old May 21, 2013 | 09:56 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: What is the block code for tpi 350 block
Look for the block number or 5.7l behind the rear of the drivers cylinder head on the block. You will also need to go with 22#hr injectors (southbayfuel injectors.com) use the promo code tuned for a discount. The computers memcal reprogramed. if you need assistance with that let me know
Old May 21, 2013 | 10:10 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
https://www.thirdgen.org/forums/sear...archid=6018602
Old May 21, 2013 | 10:19 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Look on the sides of the block, (in big numbers) it will either be 638 or 880.
If it truely is a TPI, the original is 638.
Old May 21, 2013 | 11:12 AM
M3638's Avatar
Thanks a lot guys, I appreciate ur time to reply.
Jake_92RS
Jan 28, 2020 10:37 PM
theshackle
Mar 5, 2017 06:37 PM
Reborn756
Sep 4, 2015 03:42 AM
lakeffect2
Aug 23, 2015 08:44 AM
Sanjay
Aug 12, 2015 03:41 PM
