AIR Injection Pipe Removal?
Old May 28, 2013 | 08:02 PM
THCARGUY's Avatar
Car: 1985 & 1991 Trans Ams
Engine: 350 in both
Transmission: Auto in both
Axle/Gears: 3:23 Limited Slip in both
Hi! Can anyone tell me if I need a special wrench to remove the AIR Injection Pipes? You know, the silver ones on each side of the engine that attach to the manifolds. None of my standard wrenches seem to bite real good and the nuts appear to me to be of an odd shape. Thanx!
Old May 28, 2013 | 08:13 PM
Re: AIR Injection Pipe Removal?
The nuts started out life as hexagons, like any other nuts; who knows what they might have suffered over the years though.
The tubing is 5/16". The fittings are inverted flare. The nuts are (were) ½" hex. Use a flare nut wrench. Nothing "special".
Old May 28, 2013 | 09:20 PM
THCARGUY's Avatar
Engine: 350 in both
I sure appreciate the info. I tried a 1/2" but could not get it to work. I tried both a 14mm and a 9/16" but both started the rounding process. I have sprayed heat valve lubricant on each one hoping to loosen them up. I managed to get one off with the vice grips! Thanx again.
Old May 29, 2013 | 10:27 PM
TallTim's Avatar
Car: 1989 Formula T-Top
Engine: 350 TPI, twin turbo
I got 7 of 8 off no problem. Then the pax rear broke off in the manifold. Then the extractor broke off in the hole. I read here heating with a welding flame is the only way to break some of those loose. Thus my switch to headers...
Vintageracer
Jan 10, 2020 05:33 PM
toronto formula
Nov 10, 2015 06:17 AM
TheExaminer
Aug 26, 2015 04:59 PM
db057
Aug 22, 2015 08:17 PM
3rdgenparts
Aug 8, 2015 07:09 PM
