my firebird and its accelerating hesetation
Old May 30, 2013 | 01:12 PM
rfoster23g's Avatar
Car: 92 camaro
Engine: 5.7l 350
Transmission: t5
So basically i have a 3.1l v6 firebird with 158XXX miles on it. Today i was driving it and it was running fine but about 20 min in i roll up to a red light and i try to accelerate and the car just starts bogging down to about 500 rpm and is stuttering so i put my foot farther down and it starts accelerating like normal.i thought at first my transmission was slipping or something but its not that its something with the engine.It feels almost like its not getting enough gas or something like it jerks a little bit but then catches and drives normal it only happens at dead stopps and is fine when rolling. just thought someone could point me in the right direction
Old May 30, 2013 | 09:54 PM
LHernandezJr's Avatar
Re: my firebird and its accelerating hesetation
Old May 31, 2013 | 07:37 PM
servo2055chevy's Avatar
Car: 1988 Camaro Base model
Engine: 305 LO3 5.0L V8 TBI
Axle/Gears: 10Bolt Rear, Not sure the gearing
Try cleaning your throttle body. Try fuel filter. Fairly easy to get to. Those are cheap and easy. Any local autozone should be able to see any codes stored in the system "even though your check engine light may not be on" depending on how mechanically inclined you are you can pressure test fairly easy on them also
PATRIOTIC1911
Northern Great Plains and Rocky Mountain
Oct 7, 2022 10:38 PM
Prodigious
Nov 7, 2020 09:23 AM
BewleyBizzIROC
Sep 7, 2015 08:05 PM
Americanmouse
Sep 7, 2015 12:10 PM
solocus
Sep 2, 2015 12:14 PM
