1985 Camaro spedo T5 trans and 91 Firebird ECM
Old Jun 14, 2013 | 02:15 PM
89fast5oh's Avatar
Car: 1987 Z28 IROC
Engine: 6.2L
I have a 1985 Camaro that was originally a 305 TPI w/auto trans. Years ago it was converted to a T5 with a carbed engine and all wiring ripped out. Now I am putting it back to TPI and have a 1991 Firebird L98 to use as a donor for wiring.
How or what do I need to hook up the correct VSS so that the ecm gets the right signal, the cruise will work and the cable driven spedo will work?
Old Jun 14, 2013 | 03:33 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 1985 Camaro spedo T5 trans and 91 Firebird ECM
http://www.tpiparts.net/inc/sdetail/7587, I assume the t5 is cable drive ? If you need any reprograming done send me a pm I can assist.
Old Jun 15, 2013 | 12:10 AM
89fast5oh's Avatar
Car: 1987 Z28 IROC
Engine: 6.2L
Thanks for finding that! Is that the only option for what I want done? Is there no factory part I could find at a junk yard?
Old Jun 15, 2013 | 12:14 AM
Engine: Lb9
Transmission: M20
If the t5 is a cable drive speedometer there is not a 4k ppm vss that will just screw on and work. Jags that run, tpi parts and painless wiring would be your choices. I just assume you are using a 1227730 ecm .
Old Jun 18, 2013 | 11:13 AM
89fast5oh's Avatar
Car: 1987 Z28 IROC
Engine: 6.2L
I have my cluster out to fix the trip odometer and see that there is a vss on the back. From what I read the older cars had a 2000 pulse signal and the 90-92 had 4000 pulse. Is there an item that will convert the 2000 pulse to 4000 pulse?...well one that would be any cheaper than the Tpiparts vss? I have all a complete 1991 Firebird I am using for parts. Is there anything off that car I could use?
Old Jun 18, 2013 | 11:20 AM
Engine: Lb9
Transmission: M20
The only other think I can think of if the brown wire from the buffer is a 2k optical signal that use to go to the ecm. The memcal can be reprogramed for a optical input and that signal would go to pin c6 on the 730 ecm. If you are wanting that done I can assist send me a pm.
Hotrodboba400
Dec 10, 2019 07:07 PM
Dragonsys
Sep 25, 2015 03:51 PM
88rscamar0
Sep 23, 2015 09:08 PM
dmtz956
LSX and LTX Parts
Sep 7, 2015 10:16 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
