Car was back firing now it wont start
Old Jun 18, 2013 | 03:02 PM
87IROCZCamro's Avatar
Car: Chevrolet Camaro IROC-Z,96 Vette
Engine: 350 5.7 Liter
Transmission: 700r
Hello everyone,
I was driving my car to the gym where it started back firing from stops. When I got to the gym, I shut it off and fired it up and it was back firing but started. Hour or so after I come back and it turns over but doesnt fire. While cranking it made a loud "pop" and I havent done anything sense. I got it towed home and took plugs out and saw it was running lean. I have a 383 in my car and it hasnt been running well since I have no tune yet in it. I took the cap of the distributor and it looked burned a little.Any suggestions?
Old Jun 18, 2013 | 03:22 PM
Tx 91Z28's Avatar
Car: 91/Z28/69SSCamaro/72Cheyenne
Engine: 350/350/350
Transmission: 700r4/400/350
Axle/Gears: 3.23/4.56/4.11
Re: Car was back firing now it wont start
It reads like a pole piece is bad inside the distributor.
That would cause a back fire among several other items like the timing being off.
Did you lock your distributor in place when you set the timing ? It could just be out of time.
I would like to have a 383 in mine !
Old Jun 18, 2013 | 03:27 PM
Transmission: 700r
I took the cap off and the top of it on the inside it burned it looks like. While the rotor is burnt as well with white powder all inside it.
Old Jun 18, 2013 | 03:32 PM
Transmission: 700r
Here is what they look like.
Attached Thumbnails Car was back firing now it wont start-picture001.jpg   Car was back firing now it wont start-picture000.jpg
Old Jun 18, 2013 | 03:33 PM
Tx 91Z28's Avatar
Engine: 350/350/350
That could be from the pole piece bouncing up and down making the rotor hit the cap causing your back fire. It happened to mine.
9192camaro
16
Feb 3, 2019 12:21 AM
theshackle
Mar 5, 2017 06:37 PM
TheExaminer
Aug 26, 2015 04:59 PM
justin57
Aug 20, 2015 07:05 PM
