MSD coil arching
Old Jul 5, 2013 | 07:11 PM
TPI-Formula350-'s Avatar
Car: 89 Formula 350
Engine: Forged 385 H/C/I
Transmission: 700R4-4300 Stall-lockup
Axle/Gears: BW 9 Bolt 3:70
MSD coil arching
I'm having an issue with the spark jumping from under the coil plug about 1/2" to the metal frame of the MSD coil..any ideas how to correct this?
Old Jul 5, 2013 | 07:43 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: MSD coil arching
Spark is going to take the least resistance path of resistance to ground. Check you coil wire connection and all the other ignition components. Excessive plug gap, High ignition wire resistance, condition of the cap and rotor. If this has been going on for a while there maybe carbon tracking making it easier for the spark to jump to ground.
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
school boy
Oct 22, 2015 11:47 AM
92rsvortec350
19
Oct 9, 2015 09:39 AM
meeklay812
Oct 1, 2015 03:46 PM
