Fpr or fuel pump
Old Jul 29, 2013 | 01:55 AM
danielr1211's Avatar
Car: 90 iroc
Engine: Vortec 355 w/HSR
Fpr or fuel pump
It recently aquired a 90 camaro with a hsr intake. I have a fuel pressure gauge hooked up to the line and am getting max 22psi build up without turning it over and was told it should be 45 psi. I have to turn the key over a few times to build pressure in the line an it stays at 22 for a few minutes before bleeding off. So before I went an replaced either I wanted some advice.
Old Jul 29, 2013 | 07:34 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Fpr or fuel pump
What pressure do you get when cranking over ?
I am getting max 22psi
Clamp the return line shut , run the pump and see if the pressure builds ( to what psi ?)
If it does ,reg is most likely faulty and bleeding off pressure.
If pressure does not increase most likely pump is faulty.
I have to turn the key over a few times to build pressure.
Pull the connector off the oil pressure switch and jumper the terminals.Pump will run full time with key off.
( Key on ,you are only getting 2 sec of pump run time which may be too short to see the true pump pressure )
Alternatively put 12V to terminal G of the ALDL connector under the dash to run the pump for test purposes
Old Jul 29, 2013 | 08:17 PM
Car: 90 iroc
I can't turn it over right now I sent the prom out to get reprogrammed an have a new vortec 355 motor running the stock 305 tune so trying to keep from turning it over till I have a tune for it. I will have to try the rest of your sugrstions an see what happens
Old Jul 29, 2013 | 09:38 PM
Car: 90 iroc
I clamped down the return line and the pressure stayed at 22. I wired the fuel pump hot an it pushed the psi to about 23 but goes no further then that.
Old Jul 30, 2013 | 12:45 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Seriously looking like you are going to have to drop the tank for a pump swap
May want to consider this
https://www.thirdgen.org/forums/tech...formation.html
Old Jul 30, 2013 | 12:47 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
No problem is cranking over the engine without a prom.
Nothing will happen , it will have no fuel and no spark so all it will do is crank
Oil pressure only has to build to 4 psi while cranking for the OP switch to run the pump.A good engine should get 15 -20 psi on the starter easy
Old Jul 30, 2013 | 01:43 AM
Car: 90 iroc
Yeah I figured id be doing a pump change but just had to be sure it's been a minute since iv laid hands on a car. Army takes too much time I get maybe a hour or so to wrench before I got crash, rinse, wash, and repeat.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
