Radiator with passenger side inlet/outlet?
Old Aug 5, 2013 | 03:56 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
I think I have seen some thirdgens with the inlet and outlet of the radiator on the passenger side. Am I right or crazy? I need a radiator of this design so I can run my intercooler piping easier. Any suggestions for an aftermarket all aluminum one? 2-3 core?
Old Aug 5, 2013 | 04:15 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Re: Radiator with passenger side inlet/outlet?
IDK off hand available sizes or row count.
Jegs & Summit have them advertised as Sportsman or Dragster use.
Maybe not quite what youre looking for as I'm not always on the same wavelength as most!! Lol!!
Maybe Ford or Mopar??
Old Aug 6, 2013 | 11:44 AM
FRMULA88's Avatar
Car: 1988 Formula
Engine: 421 Little M block
Transmission: TH400 w/brake
Axle/Gears: 9" 4.30s, Wilwood discs, 28X10.5-15
That is called a "double pass" radiator .
Check out Griffin...
New Griffin # 128182X double pass aluminum radiator. 19" tall X 22" wide, universal fit, Chevy only. 1 1/2" upper outlet, 1 3/4" lower outlet. Passes fluid through 2 sections to lower temperatures by 20 degrees. Wide core allows for more cooling surface. Engineered with two 1" core tubes.
Old Aug 6, 2013 | 05:06 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Thanks FRMULA88, you helped me out perfectly.
LittleFranks
Sep 17, 2015 12:22 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
corlando52
Interior Parts Wanted
Aug 24, 2015 11:32 AM
Cameeeero
Aug 20, 2015 03:06 AM
Street Lethal
Aug 14, 2015 08:25 PM
