Starting Issues
Old Aug 23, 2013 | 11:13 PM
BrandonTheZ28's Avatar
Car: 1985 Camaro Z28
Engine: 5.7 350 V8
Transmission: 5 Speed
Starting Issues
Hey peoples. My 85 z28 won't start when the engine gets hot. It starts perfectly when cold but if I drive it around for like 30 min - 1hr, I turn it off and it won't turn over. It sounds like its trying but just won't turn over. Then I leave it cool for a little like 20 - 30 min it will start. I replaced the ignition control module and it still does it. I bought a heat shield for my starter but It doesn't even fit at all. Now I have to do all this cutting to make it fit. Anybody have a problem with their headers heating up their starter? I heard it could be that, hence why I bought the heat shield. My header pipe is kinda close to the starter, I could see it happening but any ideas if the heat shield would work? And does anybody have pics of a heatshield installed because I need an idea how to attach mine anyway.
Old Aug 24, 2013 | 12:26 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Starting Issues
Originally Posted by BrandonTheZ28
won't start when the engine gets hot. Then I leave it cool for a little like 20 - 30 min it will start.
Nearly anybody with a SBC and headers ;Google "SBC Hot Start Problem "
You will get results like this
http://www.chevyhiperformance.com/te..._no_start_fix/
http://www.streetrodstuff.com/Articl...tart_Problems/
www.thirdgen.org/solenoid
It is called a IGNITION control module because it controls the ignition ( spark ) ; nothing to do with the starter.
Old Aug 25, 2013 | 04:05 AM
Engine: 5.7 350 V8
Re: Starting Issues
So no to the heat shield? lol And so to get rid of this problem, I have to create an alternate solenoid and run all the wires to the solenoid? Why wasn't this happening before? Like I kinda noticed a difference in hot and cold starts but nothing this dramatic until now. Oh and thank you for being the 1 reply out of like 70 views!
Old Aug 25, 2013 | 01:15 PM
plilikoi's Avatar
Re: Starting Issues
I suggest checking the fuel pressure and pressure regulator. I had a similar intermittent starting problem that was caused by a bad fuel pressure regulator.
[edit]
Sorry, I didn't notice that you said it wouldn't even turn over. Maybe your battery is weak?
Old Aug 25, 2013 | 05:19 PM
Engine: 5.7 350 V8
Re: Starting Issues
[edit]
I already checked the battery, its fine. that was the first thing that I actually checked when this first happened. The other guys help actually seems legit. but thanks for the imput.
Frozer!!!
Jan 19, 2024 04:55 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Bryan F
Aug 18, 2015 02:28 PM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
86Base
Aug 8, 2015 01:34 PM
