Thirdgen Tech "How To" Videos
Old Nov 23, 2013 | 11:18 PM
  #51
gm muscle's Avatar
Car: '89 Iroc-Z
Engine: 5.7 TPI
Transmission: 700 R4
Axle/Gears: 2.77
Re: Thirdgen Tech "How To" Videos
Originally Posted by Veaceonee
Remove the solenoid and twist, out it comes.
I wish I'd known that!
I was replacing the starter on my L69 '87 Monte Carlo SS. I tried removing the Y-pipe and broke just about every damn bolt! That led to me buying the Edelbrock TES headers and high-flow cat.
Old Nov 24, 2013 | 11:35 AM
  #52
BlackJet's Avatar
Car: 1988 Formula 5.7
Great vids Manolis, fun to watch and learned quite a few things.
Keep up good work.
Old Nov 24, 2013 | 09:24 PM
  #53
manolis1969's Avatar
Car: klowny1969 <-youtube 4 3rd gen vids
Engine: subscribe to klowny1969 on youtube!
Transmission: subscribe to my channel on youtube
^Thank u and thanks to all my subscribers
Below is how to remove thirdgen ball joints..the tool can be rented from autozone ..enjoy
Old Nov 25, 2013 | 09:24 PM
  #54
The above video shows the following:
How to use a ball joint press tool
How to install a ball joint
How to remove a ball joint using a hammer and jack stand
Old Nov 25, 2013 | 11:03 PM
  #55
gm muscle's Avatar
Car: '89 Iroc-Z
Engine: 5.7 TPI
Axle/Gears: 2.77
I'm still on the look out for that video on how to replace the fuel pump.
Old Nov 29, 2013 | 11:31 AM
  #56
sorry i have a car in my backyard specifically for that video..getting cold here and holidays got me busy..but i will do it
Old Nov 29, 2013 | 07:10 PM
  #57
gm muscle's Avatar
Car: '89 Iroc-Z
Engine: 5.7 TPI
Axle/Gears: 2.77
No rush of course...the one on my Iroc is working just fine, but its just a matter of time 'til the dreaded day comes. I just want to be informed and ready.
Old Dec 2, 2013 | 05:40 PM
  #58
edit
  #59
Lol no prob
Here is a 2013 bloopers vid..enjoy:
Old Dec 3, 2013 | 09:01 PM
  #60
^ how to replace a ball joint - FULL Version
Old Dec 3, 2013 | 09:02 PM
  #61
edit
Old Dec 4, 2013 | 12:50 PM
  #62
Old Dec 6, 2013 | 09:20 PM
  #63
^ Holley Double pumper Main body Upgrade / How to rebuild a holley
Old Dec 6, 2013 | 09:22 PM
  #64
Old Dec 6, 2013 | 09:23 PM
  #65
^ How a holley double pumper carburetor works
Old Dec 6, 2013 | 09:28 PM
  #66
^ How to change a fuel filter on a thirdgen
Old Dec 6, 2013 | 09:30 PM
  #67
^ How to replace your car cigarette lighter
Old Dec 6, 2013 | 09:38 PM
  #68
^ how to replace a steering column
Old Dec 6, 2013 | 09:42 PM
  #69
^ How to change a heater core part 1
Old Dec 6, 2013 | 09:43 PM
  #70
^ Heater core replacement part 2
Old Dec 6, 2013 | 09:46 PM
  #71
^ I tested my Moroso crankcase evacuation system
Old Dec 6, 2013 | 10:02 PM
  #72
Come check out my thirdgen channel on youtube !! Just search for: KLOWNY1969 ...and you can also subscribe for free to be notified whenever i post a new thirdgen vid
Old Dec 7, 2013 | 03:31 AM
  #73
NCC-2569's Avatar
Car: 1990 Trans Am
Axle/Gears: Stock
Wow! Thanks!
Old Dec 7, 2013 | 08:22 PM
  #74
crystal383's Avatar
Originally Posted by init4fun
Thank You Manolis , your videos are great and I understand if it takes a while to get around to the seat belt button thing , seeing all the other videos you have to get to .
Also , if your looking for third gen specific PIA repairs , how about a vid of changing the frame mounted portion of our engine mounts . The first one I did (my 87 TA) I ended up taking out the springs to get at the hardware hidden in the frame , but by my second one (my 89 Firebird) I had gotten the crazy idea to reach in between the spring and frame and using a stick welder I put a little tack weld on each of the three nuts to hold them to the frame so the bolts would come out . No big welds , just a couple of light tack welds on each that could be broken off in the future should the need ever arise . I shot a little bit of paint in there when I was done to prevent rust and did the job in a couple of hours instead of a couple of days (like the first one I did) .
It is a ROYAL pain! I was replacing my stock rubber mounts with some polyurethane mounts so I had to take the whole unit off. I ended up squeezing between the A-arm and the k-member with an extension and a wobble joint to hold the bolt still while I broke the nut loose with the other hand on top. To get the bolts back through the holes I tied fishing wire to the tip of the thread part of the bolt. Took some bailing wire, made a loop on the end so I could help put the fishing line through the right bolt hole. Had someone above to grab the wire. Then pull the bolt up through the hole and hold it till I could get my my socket with the extension and wobble behind it so I could put the nut on. To do all six bolts it took about 4 or 5 hours.
I'm sure your video will be much easier.... Haha.
Old Dec 8, 2013 | 01:20 PM
  #75
9340Ruby's Avatar
Car: 1991 Z28 Convertible
Axle/Gears: 3.23 pos
Thank you for all of the videos. I especially like the heater core removal since I am in the process of this myself and that has helped a lot. Do you recommend a certain brand? Thanks.
Old Dec 8, 2013 | 06:04 PM
  #76
Your welcome guys..more videos to come..been feeling under the weather lately
As far has heater cores..ive used the regular ones you find at the auto parts store for like 30$..u can also jb weld the tubes where they exit the heater core cause thats where they usually leak..for an added measure of safety
Old Dec 8, 2013 | 11:28 PM
  #77
Stampe's Avatar
Great work! Thanks for all the vids!
Old Dec 9, 2013 | 09:36 AM
  #78
9340Ruby's Avatar
Great tip about using JB Weld! Thanks!
Old Dec 9, 2013 | 10:40 PM
  #79
You got it guys! Thanks for watching!
Old Dec 10, 2013 | 09:25 PM
  #80
Old Dec 10, 2013 | 09:28 PM
  #81
Old Dec 10, 2013 | 09:29 PM
  #82
^my car..going to my car club meet
Old Dec 10, 2013 | 09:39 PM
  #83
Old Dec 10, 2013 | 10:28 PM
  #84
Old Dec 12, 2013 | 12:10 AM
  #85
321FormulaGuy's Avatar
Car: 1990 Pontiac Firebird Formula
Engine: 89 Camaron IROC-Z 350
Originally Posted by manolis1969
I might do a gas tank / fuel pump replacement video this weekend
Have you done this Video yet?
Old Dec 12, 2013 | 10:25 AM
  #86
^ not yet..i will though..patience grasshopper lol
Old Dec 13, 2013 | 07:01 PM
  #87
Bump
Old Dec 14, 2013 | 10:01 PM
  #88
^ How to properly flush your cooling system ..i initially did it on an impala but at the end i describe how to do it on a thirdgen..enjoy
Old Dec 15, 2013 | 08:42 PM
  #89
^ again i discuss at the end of the video how to bleed the coolant in a thirdgen..its basically the same principal
Old Dec 16, 2013 | 04:27 AM
  #90
RavageTheRoad's Avatar
Car: 1991 RS
Engine: L69?
Man you are a godsend here! The ball joint, front end rebuild, steering column, and heater core vids just gave me my blueprint to fix the last few problems on my saved from the grave car. I hate to ask since you do so much here but wny way you could do a vid on the steering box adjustment? I can't tell if my play is the column or box but i'm sure it would be a huge improvement either way.
Old Dec 17, 2013 | 07:14 PM
  #91
If i get a chance i will..but keep in mind..these cars had some slop from the factory..that was normal lol ..
Old Dec 17, 2013 | 08:37 PM
  #92
^ How to clean fuel injectors
Old Dec 18, 2013 | 09:50 AM
  #93
For the above OTC fuel injector cleaner, I just bought the can by itself..and then i used the attachements from my fuel pressure tester...I mentioned all of that in the video...enjoy
Old Dec 18, 2013 | 02:38 PM
  #94
Old Dec 24, 2013 | 10:47 AM
  #95
The above video is something i threw together real quick a while back.. i go into detail on how a distributor works and differences between the modules found in them..
Old Dec 26, 2013 | 02:30 PM
  #96
^How to plug a tire
  #97
Old Dec 27, 2013 | 06:38 PM
  #98
Still taking video requests!!!
Old Dec 28, 2013 | 05:11 AM
  #99
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
How To Plug A Tire - YouTube
^How to plug a tire
im glad to know how to patch a tire now but was disappointed the blond wasn't in the video.lol
Old Jan 3, 2014 | 01:14 PM
  #100
LOL .. I was perusing google images and found that pic..thought it was nice haha
