Thirdgen Tech "How To" Videos
Car: klowny1969 <-youtube 4 3rd gen vids
Engine: subscribe to klowny1969 on youtube!
Transmission: subscribe to my channel on youtube
Re: Thirdgen Tech "How To" Videos
Check out my channel : klowny1969 for videos such as how to diagnose faulty power door locks..I go through a whole wiring schematic and show you step by step how it looks in the diagram and the car itself...
I also have videos on window wiper replacement...
So the past few weekends ive been wiring my detached garage for a 100 amp subpanel..for my future welder and lift...and gathered everything into two videos...
First video I explain how to wire it..I include wire diagrams and show u the finished product..
Second video, I take you step by step through the entire process..enjoy..
Thank u for watching
Bump..doing a bunch of recording in next couple of weeks...stay tuned
Will be doing a timing video this weekend
Thanks for subscribing and watching my vids guys..I appreciate all the support..never thought I would have close to 3 million views in about a year of doing this!!
Below video is a quick video of a car that was on the side of the highway..a thirdgen!! And his alt bracket broke..all I had was some rope..and the rest is in the vid lol..he also made it 20 miles home!! Lol
How to wire tie bolts..demonstration on a wilwood setup for thirdgens...
Car: 89 formula 350
Engine: ls1 magnuson tvs2300 supercharger
Axle/Gears: 4.11 Dana 44!
are there any monetary kickbacks to these videos? I'm seeing them spammed on my local Craigslist as well. I think there are rules for having to be a paid vendor for items like this.
How to wire your speedo on a thirdgen using a dakota digital box.. the car in the video is a GTA that originally came with a 700r4 but he swapped to a t56 and couldnt get his speedometer to work..I go into detail on how to fix this issue...hopes this helps some of u..
Bumpsky
Replacing hydraulic lifters on a small block chevy:
How to change a brake hose
How to check an idler arm for wear :
How to replace rear lower control arms..car is an impala but the same applies to thirdgens...
Car: 1990 Trans Am
Axle/Gears: Stock
Just to let you know... we're still watching
Great job on those videos, man. Keep it up
Btw: You pronounce "ground" just like Arnold Schwarzenegger would
Lol thanks man..
Here is a video on how to replace a torque arm bushing..I used a Polyurethane one in the vid..enjoy..
For the beginners: how to change a thermostat on a thirdgen v6 3.1...
How to fix a broken headlight switch plastic nut on a thirdgen camaro...
just did a tubular k-member install on a GTA ..in the process of putting the video together
^ Thanks
^ How to install a tubular k-member..this particular one is a UMI. .
^I just did a video on boring out the cylinder with the heads on
Bloopers
Car: 1991 Trans Am Vert
Engine: 5.0 TPI
Transmission: T-5 baby
Lol sorry
Below is a video on how to hook up a brake pressure gauge on your thirdgen. this gauge can be used to diagnose a bad master cylinder, combo valve, lines etc...
enjoy..
enjoy..
Hmm i'll look into podcasts, never really thought about it...thanks.
and thanks for watching guys..i have some more thirdgen tech videos i shot this last weekend..will upload them in the next few days..
My latest vid..how to change control arm bushings on a thirdgen..i used the cheapest way possible to do the job lol
How to replace a timing chain on a thirdgen..car is a v6 but the procedure is basically the same for an 8..
Too cold here to work on cars!! Lol
You have a video of how to run the wiring for a older motor swap.. I have 90 rs camaro and I wanna put a 1985 305 carb motor in.. How would I setup the wiring? Do I remove the computer and wiring harness?? ..any advice's would help thanks.
U can pretty much ditch the computer if u do that swap..if u put a hei distributor in, u pretty much have to wire an ignition hot wire to it and ur ready to go..
Astrovan / safari steering shaft upgrade...
Car: 1989 Camaro
Engine: 350 but it's torn down right now.
Axle/Gears: I'm working on it,lol.
I'd like to see a vid of you removing the exhaust manifolds and exhaust for upgrades like headers and such. Seen a lot of questions about that. That would help a lot of people here immeasurably! Fuel pump change is another question a lot of people have too. Been a subscriber to you for a while now, so I know they'd be great and help out lots of people on here. Keep up the good work
Thanks guys..fuel puml vid is on the way..been overhauling my garage so my videos have been slowing down..but will pick back up
I have a door lock actuator vid..just scroll through my channel..thanks
Here is a vid on how to change a door latch mechanism..its on a 2nd gen , but its the same procedure pretty much on a thirdgen...enjoy
Car: '89 Iroc-Z
Engine: 5.7 TPI
Transmission: 700 R4
Axle/Gears: 2.77
I'm still patiently waiting on how to replace a fuel pump on fuel injected thirdgen...I've read plenty as to what is involved. It is different to see it though.
Transmission: 5-Speed Manual
Below are two vids..one on how to change a front strut..and the second is how to replace a strut mount..i also show examples of a bad strut and mount and how to diagnose!
Dont forget to subscribe to my thirdgen channel
How To Replace and Diagnose a Bad Strut Mount - YouTube
Can You Safely Remove The Strut Mount Without Completely Removing The Strut From The Vehicle.
Car: 1990 Trans Am
Axle/Gears: Stock
I replaced my idler arm and the service manual called for a tool J 33093 to measure the distance between a machined surface on the relay rod and a bolt on the k-member.
Any idea how to use that tool?
A tutorial on how to remove and install all that steering linkage stuff would be great.
Edit: Never mind. Just found the video. Thanks!
Still got the question about the tool, though. The alignment shops over here never heard of it.
Im finally back to recording videos..had to remodel my garage and buy better camera equipment..
To answer some of ur questions...
Yes..you can measure the distance to get the relay rod parralel with the rest of the car..
I will be doing a fuel pump vid very soon on my twin turbo gta build
Below is a quick video on how to clock the alternator..the car was a 92 gta with a powermaster alt..
Video below shows how to drill and tap a block if you have a 153 tooth flywheel / flexplate and your block can only accommodate a staggered bolt pattern starter..
Below is a 4L60e swap into a 2nd gen..but it can be used for reference on a thirdgen as well...
how to calculate you rear gear ratio without taking anything apart..
