84 carb car w/in-tank pusher pump, where is the relay that controls it?
Old Sep 27, 2013 | 08:41 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
I've got an 84 that had the in-tank pusher pump added to it. I replaced my in-tank pump some years back with a 255lph wahlboro unit but ran an external fuel pump relay to power it. I'd like to use the factory harness but I have no idea where the relay in the engine bay is. I do know that there was no fuse in the fuse box at the time I did the change over so the pusher-pump wasn't operational. When I did the swap over, I did put a fuse in the fuse box to see if that would give me power to the connector but it didn't. So more than likely the relay or the wiring is bad...I'd like to start with the relay.
Does anyone have a picture or good description of where the relay would be? Any help would be greatly appreciated!
Old Sep 27, 2013 | 09:10 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: 84 carb car w/in-tank pusher pump, where is the relay that controls it?
On later cars it is by the brake booster
Old Sep 27, 2013 | 09:18 AM
Ozz1967's Avatar
Car: 1984 Trans Am
OK, thanks. The relay you have labeled as the fuel relay is the "Fan relay" on my car. But I believe I have a second relay behind it...I'll check and see after work today.
Thanks!
Old Sep 28, 2013 | 06:23 PM
FlippindaBird's Avatar
Car: 1987 Firebird, Dad bought it new
Engine: 5.7L Vortec w/ LT4 Hot cam
Transmission: 700r4 transgo shiftkit 2600 stall
Axle/Gears: 3.42 '02 SS 6 spd rear
wondering what you found out about this, im going to be ditching my ecu and I want to use the fuel pump relay to turn my intank on and off as well... sub'n
Old Sep 30, 2013 | 11:55 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
These were taken from an 85 Shop manual for the "G" code 'HO' engine - but the set-up should be the same in your 84.
That should be enough info to ge the system workin' again !
Old Oct 1, 2013 | 03:05 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
You can ditch the pump relay and just use the OP switch / wiring to run the pump the same way it does stock as the backup to the relay
As soon as the engine cranks over the pump runs and it turns off when the engine dies.
No need for any wiring to the key or extra wiring as some do with carb swaps
Old Oct 1, 2013 | 08:47 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Thanks for the photo! I'll take a look at mine tonight at home, but I'm pretty sure that's the fan relay on my car. However...there are two of those relay's. I'll take a picture tonight and post what mine looks like.
RazorN8
Jan 7, 2022 11:44 AM
midge54
Dec 27, 2019 04:14 PM
theshackle
Mar 5, 2017 06:37 PM
midge54
Jan 29, 2017 07:00 PM
Kaweh
Aug 9, 2015 02:54 PM
