88 Trans AM. Passenger Side Headlight Motor Repair. Need to remove motor?
Old Oct 26, 2013 | 12:32 PM
GTA88's Avatar
I have the classic balky headlight situation on my 88 GTA.
I seem to remember reading somewhere that in order to replace the three plastic "inserts" that disintegrate over time, you do not have to actually remove the whole motor, on the passenger side. I took a look, and it looks like you can get a tool on the 3 bolts that hold the cap on the side of the motor, and take the cap off to access the 3 "inserts".
Anyone know? Anyone done it?
Thanks.
Old Oct 26, 2013 | 01:53 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Re: 88 Trans AM. Passenger Side Headlight Motor Repair. Need to remove motor?
Do it the easy way. Four screws and you've got the entire headlight assembly on the bench where you can comfortably clean and grease the gears, and install your new drive bushings.
Old Oct 27, 2013 | 07:39 AM
BlackJet's Avatar
Car: 1988 Formula 5.7
Thanks.
I did this last year on both sides of my 88. The bushings turn to dust over time due to the material used from the factory I am told. That said, it's not overly difficult. The bushings ran 17.00 and seems I ordered from a vendor named Rodneys in Minnesota. Both motors need removed, 3 bolts each and the lifting rod detached. Once put back in, the motors learn their position on their own. Hardest part was just being patient because of the confined space. I can find the vendor for you if needed.
Old Oct 27, 2013 | 02:07 PM
GTA88's Avatar
Thanks for the responses! I hope my work goes as smoothly as yours did.
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
IROCThe5.7L
Aug 10, 2015 11:24 AM
marcusaw
Aug 10, 2015 08:13 AM
