I need help. Changed oil Presure sensor Now Injectors wont fire.
Old Oct 27, 2013 | 04:34 PM
Blackbird down2's Avatar
Car: 91 Formula
Engine: 305 TBI
I noticed oil drizzling out of my oil pressure switch, replaced it. Immediatly after, injectors on TBI stopped working. Installed new fuel pump. Fuel pumping, but no fuel comming out of injectors. Saw that Oil pressure switch has low pressure cut out to injectors in a schematic. Oil pressure sensor seems to work, as pressure on guage increases as engine cranks. What is going on? What is the next step? How do I fix this? One of you wizards must know.
Old Oct 27, 2013 | 06:06 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: I need help. Changed oil Presure sensor Now Injectors wont fire.
Did you disturb any wiring while replacing the switch?.
If the ECM doesn't see the signal from the dist it won't fire the injectors
The OP switch is a back up to the fuel pump relay, it lets you start your engine if the pump relay fails. It does not cut off the fuel.
Old Oct 27, 2013 | 08:52 PM
Car: 91 Formula
Engine: 305 TBI
Did'nt touch any wiring, except connector to Oil pres sensor.
eightsixseven
Dec 16, 2024 01:50 PM
maroe624
Apr 16, 2017 08:29 AM
Navy8125
Aug 21, 2015 09:32 AM
92camaroJoe
Aug 13, 2015 06:07 AM
