85 ac delete
Old Nov 17, 2013 | 05:16 PM
edlisaj's Avatar
85 ac delete
anyone know what size(#)belts to use on 85 l69 iroc 4bbl with the compressor removed?looking to run both belts on the ps pump
Old Nov 17, 2013 | 08:02 PM
Project86B4Z's Avatar
Car: 85 camaro RS RIP\ 86 IROC-Z :)
Engine: 2.8 MPI V6\ carbed LO5 5.7 v8
Transmission: 700r4 auto
Axle/Gears: 3.42\ posi 3.73
Re: 85 ac delete
Im running a 4bbl on my 1990 LO5 with no A/C or A.I.R. but im running the same multiple belt style as your's the numbers i saw on my belt 100 / CR the belt might be about 12-15" long. But im pretty sure that any part store should be able to help there are two setups: Power steering to crank to water pump thats what im running and the second one Power steering to crank to water pump to A/C unless some how the A.I.R (smog) pump is included but the store should be able to help.
Old Nov 18, 2013 | 08:14 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: 85 ac delete
Run a long piece if twine of string around the pulleys in question. Measure the length where it meets. That'll tell you what length you need.
jaridjohn
Oct 5, 2015 07:01 AM
djmarch
Oct 2, 2015 10:41 PM
Zell1luk
Sep 29, 2015 10:36 AM
