Compatibility questions using '94 TBI 350 block for L98
Old Nov 22, 2013 | 07:52 AM
lavamadness's Avatar
Car: 1989 Formula 350
Engine: 5.7L (L98)
I'm in the process of swapping all the TPI gear onto a '94 truck block for my '89 Formula 350. Everything has been straight forward so far *crossing fingers*, but I have a question for the last couple of components.
1) The flywheel from the truck motor is much larger than the L98 flywheel. Should I expect any problems, like with balancing?
2) A minor issue, but I'll mention it anyway... The oil pressure sending unit "nut" hits the truck block before it is screwed in very far. I was just going to try grinding it down until it cleared (on the sending unit, not the block).
MustangBeater20
Oct 29, 2022 09:20 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Vintageracer
Jan 10, 2020 05:33 PM
Reborn756
Sep 4, 2015 03:42 AM
redmaroz
Aug 16, 2015 11:40 PM
