Fuel pump/filter ?
Old Dec 11, 2013 | 09:12 PM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Fuel pump/filter ?
I have done allot of reading on the subject of changing the fuel filter but my question is about this statement I found. = "The oil pressure sending unit doubles as a fuel pump relay by-pass. When you pulled the fuses it kept running because the OP sending unit kept supplying power to the pump."
If this is true exactly what needs to be done to change the fuel filter?
Old Dec 12, 2013 | 06:21 AM
Restrorob's Avatar
Car: 88 GTA
Engine: Built 355 to install
Transmission: Built turbo 350
Re: Fuel pump/filter ?
Disconnect the battery (power source) ......
Old Dec 12, 2013 | 11:52 AM
Engine: TBI,5.0
But I have to run the car out of gas in the lines.
Old Dec 12, 2013 | 12:05 PM
Restrorob's Avatar
Car: 88 GTA
Huh...... Bleed the line pressure off at the service port on the fuel rail (being careful), Shouldn't be no need in running the car/lines out of fuel.
Old Dec 12, 2013 | 12:26 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Disconnect the relay.
Old Dec 13, 2013 | 12:52 AM
Engine: TBI,5.0
Thanks guys,
I had a shop put it on a lift so we could get at it. He simply used one of those tall fluid catch cans and took off one side of the filter with fuel flowing out a little and did the other side. Fuel still trickling out. Put the new filter on. Done. It cost me $20.00 for about 3 minutes work under the car.
I consider myself a pretty smart guy and try to do all the work on my car. All of this is new to me being my first build but watching him do that made me feel kind of low. I could not even replace a fuel filter .Well know I know.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
mike_c
Aug 27, 2015 04:32 PM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
