coil problem?
Old Dec 19, 2013 | 06:18 PM
EvelBist's Avatar
Car: 89 Black GTA
Engine: 'close to' stock 5.7 but trending>>
Transmission: 700
coil problem?
no start this morning - cranks, but no start. This afternoon i put a spark plug light between the coil and dist. at first, cranking produced no light. but after about 10 seconds, the light started showing up and car immediately started.
Help! what does this indicate - bad ICM, coil, wires somewhere, ????
Old Dec 20, 2013 | 06:58 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: coil problem?
You might want to see with a noid light if you have injector pulse. Or even a tach signal . If you do chances are your icm is good and the issue is in the jumper going from the icm to the coil , high resistance in the coil wire, cap terminal or carbon button.
Old Dec 20, 2013 | 07:02 PM
Engine: Lb9
Transmission: M20
Re: coil problem?
You might want to check the ohm resistance of the primary and secondary coil windings on your ignition coil.
Old Dec 20, 2013 | 10:39 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: coil problem?
http://easyautodiagnostics.com/gm_ic...n_module_1.php
Old Dec 21, 2013 | 07:34 PM
EvelBist's Avatar
Car: 89 Black GTA
Transmission: 700
Re: coil problem?
for the record, the "new" delco coil had low resitance in the secondary. got it from rockauto, so maybe it was on the shelf a long time but there really is no excuse for that. i put back the accel coil that was there before i "went back to stock" and havent had any problems for several days.
'if it aint broke ... ' o well.
92camaroJoe
Jul 29, 2023 07:57 PM
mddaniel
Sep 8, 2015 05:16 PM
Bryan F
Aug 27, 2015 07:28 AM
92camaroJoe
Aug 13, 2015 06:07 AM
