1989 305 Cylinder Head Ussue
Old Jan 3, 2014 | 11:11 AM
buckweber's Avatar
Car: 1989 RS Convertible
Engine: 305 TBI
Transmission: Automatic
Engine runs fine but puffs smoke after sitting at a long light. Does not smoke during startup or normal driving. I lose a quart of oil between oil changes.
I did install valve seals which improved the issue. I am thinking my valve guides may be causing the problem.
I assume to correct I would need to pull the heads and have a valve job done.
I have very little budget. If I do a valve job, do I need to replace, springs, rocker arms, push rods, cam????
In addition, if that is not the problem, I will need to start digging into the bottom end. If so, I am looking at a complete slow rebuild of the motor.
Should I need to go that deep it may be more economical to let it smoke until I can come up with the funds for a crate motor.
Any guidance would be appreciated. Killing mosquitos after taking off from the light is a bit embarrassing.
Thanks,
Buck
Old Jan 3, 2014 | 02:22 PM
Hylton's Avatar
Car: A Camaro of some sort.
Re: 1989 305 Cylinder Head Ussue
Before you get into all of that, do compression and leak down tests for each cylinder. It will shed some light on your problem.
Old Jan 3, 2014 | 08:17 PM
Damon's Avatar
I think that's your answer.
If you start digging too far into an old motor you'll eventually just realize that a full rebuild is needed most of the time. Even if you identify the problem dead-bang , the solution is usually "yank it, machine it, rebuild it." And then you're right back where you started.
Old Jan 8, 2014 | 03:20 PM
buckweber's Avatar
Engine: 305 TBI
Thanks to all. You helped confirm reason.
84z96L31vortec
Aug 20, 2017 12:16 AM
NinjaNife
Aug 23, 2015 11:49 AM
kyleb24
Aug 15, 2015 08:24 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
