Quick dumb question...curious lol
Old Jan 27, 2014 | 05:20 PM
Mrbanados's Avatar
Car: 84 Camaro z28
Engine: 355
Transmission: Th350
Axle/Gears: 4.10
What causes that crackle kind of idle? Is it the actual cam itself plus the kind of exhaust? I'm guessing it has something to do with duration? Or overlap? Almost sounds like marbles coming out the exhaust lol..just think it's sounds bad ***
Old Jan 27, 2014 | 05:37 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Quick dumb question...curious lol
Originally Posted by Mrbanados
Or overlap?
"More overlap makes a choppy idle and tends to make peakier power for the same reason as a narrow LSA does. More overlap and the subsequent lower intake manifold vacuum might mean giving up vacuum-driven accessories like power brakes."
See
http://www.crankshaftcoalition.com/w...mshaft#Overlap
Old Jan 27, 2014 | 06:11 PM
Mrbanados's Avatar
Car: 84 Camaro z28
Engine: 355
Transmission: Th350
Axle/Gears: 4.10
Originally Posted by vetteoz
"More overlap makes a choppy idle and tends to make peakier power for the same reason as a narrow LSA does. More overlap and the subsequent lower intake manifold vacuum might mean giving up vacuum-driven accessories like power brakes." See http://www.crankshaftcoalition.com/w...mshaft#Overlap Video Link: http://www.youtube.com/watch?v=Pa3mKXN-tIY
Thanks!
Old Jan 27, 2014 | 06:17 PM
Mrbanados's Avatar
Car: 84 Camaro z28
Engine: 355
Transmission: Th350
Axle/Gears: 4.10
So what if a cam has negative overlap? Like -15?
Old Jan 27, 2014 | 07:28 PM
1gary's Avatar
Going to stick with the same mgs.Compression ratio dictates what cam should be chosen.
Any cam chosen for the "sound of it",is a poser cam used by a poser end user.Hate that!!.
Old Jan 27, 2014 | 07:42 PM
Mrbanados's Avatar
Car: 84 Camaro z28
Engine: 355
Transmission: Th350
Axle/Gears: 4.10
Originally Posted by 1gary
Going to stick with the same mgs.Compression ratio dictates what cam should be chosen. Any cam chosen for the "sound of it",is a poser cam used by a poser end user.Hate that!!.
I know that! I was just curious
F-body-fan
Jan 12, 2023 01:49 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
meeklay812
Oct 1, 2015 03:46 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
3.8TransAM
Sep 27, 2015 08:37 PM
