Need help with fuel pump. 89 irocz 5.7
Old Apr 2, 2014 | 02:38 PM
zombi_360's Avatar
Car: 1989 IrocZ
Engine: 5.7 350
Transmission: TH-700R4
Axle/Gears: 2.77
ok well, I got the car last year in February as a project. Hasn't been running since 2001. First thing I did was replace the fuel pump, strainer and filter. Put in a new rear main seal, oil pan gasket, timing cover gasket, water pump gasket. New harmonic balancer, battery, cap rotor, spark plugs, ignition wires. Being under the car I noticed the knock sensor and oil pressure sensor were off. I put the knock sensor back on. I bought a new oil pressure sensor too put haven't done it yet. As it sits I tried to prime the fuel pump to see if would kick on and nothing happened.
Is this because the oil pressure sensor is not hooked up? Or maybe I have to replace another relay. Any and all help is appreciated.
92camaroJoe
Jul 29, 2023 07:57 PM
Grant2k
Jul 10, 2018 04:01 PM
theshackle
Mar 5, 2017 06:37 PM
AkDrifted
Aug 17, 2015 07:45 PM
92camaroJoe
Aug 13, 2015 06:07 AM
