EGR Temp Sensor used on Speed Density Cars?
Old Apr 2, 2014 | 08:17 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
I am in the middle of converting my car over to speed density. I have heard that speed density cars don't have the EGR temperature sensor. Is there any truth to this? If so, do I just block the hole for it or get a new EGR valve?
Old Apr 2, 2014 | 08:33 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Re: EGR Temp Sensor used on Speed Density Cars?
I justed checked a 1992 TPI wiring diagram, and I could not find the EGR temp switch. Suprising that it's not on there, the older models definitely monitored EGR function.
Old Apr 2, 2014 | 08:36 PM
Jeffs82TA's Avatar
never had it
Old Apr 3, 2014 | 07:42 PM
Vader's Avatar
S-D versions sensed the EGR action via a MAP change, rendering the diagnostic temperature sensor unnecessary.
Old Apr 3, 2014 | 08:56 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Thanks for the replies. So can I still use the MAF EGR valve?
Old Apr 4, 2014 | 08:16 AM
bestracing's Avatar
Car: 86 T/A - 70 Z28/RS
Engine: Broke - 350
Transmission: 700R4 - M22
Axle/Gears: G80, 2.73 - ZQ9 G80 4.10
The valves work the same and bolt on the same so I would say you could use the old one. You would just have a sensor that's not connected or used anymore.
9192camaro
16
Feb 3, 2019 12:21 AM
kyleb24
Aug 15, 2015 08:24 AM
86Base
Aug 8, 2015 01:34 PM
drathaar907
Aug 6, 2015 04:20 PM
