Rusty Coolant
Old Apr 6, 2014 | 07:20 PM
DirtySpleen's Avatar
Car: 1991 Camaro RS
Engine: 5.0 L03
Axle/Gears: 3.43 Torsen 10 bolt
Rusty Coolant
So my coolant is rather discolored. My car leaks/burns off the coolant somehow, but slowly. The coolant ends up turning a redish brownish color as well. What could this be? Hoping its not a head gasket issue
Old Apr 6, 2014 | 07:59 PM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
Re: Rusty Coolant
you say it goes away?? do a pressure trest on it and look for visual outside leaks. then check your plugs,maybe do a pressure test while they are out. do you have oil that looks like a milk shake??
Old Apr 6, 2014 | 08:15 PM
Car: 1991 Camaro RS
Engine: 5.0 L03
Re: Rusty Coolant
It seems to be leaking around the intake manifold.
Old Apr 6, 2014 | 08:53 PM
joshc's Avatar
Car: 1986 Trans Am
Re: Rusty Coolant
Has the coolant been maintained with regular flushing?
Conventional green coolant is only good for about 2 years, then the anti corrosive additives wear out. If it hasn't been maintained, the block probably has lots of rust in it thats floating around in the system.
I would fix the leak first then flush the system good and install fresh coolant.
sheachopper
Jul 31, 2019 11:27 AM
ULTM8Z
Oct 2, 2015 01:25 PM
