Spark Plug Wire Looms with Centerbolt Valve Covers
Old Apr 21, 2014 | 08:42 PM
1982Camaro383's Avatar
I have a 1982 Camaro with 350 chevy engine. I have the Sanderson QP1200 headers. I am looking for a nice wire loom set for my centerbolt valve covers to be able to route the wires away from heat. Any help would be greatly appreciated. Pics would help as well.
Old Apr 21, 2014 | 11:11 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Spark Plug Wire Looms with Centerbolt Valve Covers
I have the Russell # 611147 shown blow.
I got the best clearance on the headers as shown but they come with a single and a 3 wire holder as well
Currently shown as unavailable most places but SDPC have them listed ?
https://sdparts.com/index.php?q=deta...ucts/rus611147
Only other CB ones appear to be the holders that mount to the valve cover bolts
See
http://www.summitracing.com/int/sear...r?PageSize=100
Old Apr 22, 2014 | 06:09 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
I made up my own by modding four two-wire generic looms (I think they were Accel brand) and some 90-degree angles from the cabinet hardware aisle at the hardware store.
I separated the plastic wire holders from the looms and pop-riveted them to the 90-degree angles.
On stock Chevy heads and some aftermarket heads, there are two small threaded holes (IIRC they're No. 10 machine screws??) located in between the exhaust ports.
I screwed my modded wire looms to these holes.
No's 5-7:
No's 2-4:
The other two looms are identical to these.
My SLP headers have individual flanges for each port. I don't know if these as-modded looms will work with the more common single plate header flange. You can probably fab up some longer or different shaped angles in order to use the same threaded holes.
They're not pretty but they work. Most people don't even notice them. I've been running these since 1989 without issues.
Old Apr 22, 2014 | 08:28 PM
Attached is a pic of the headers & centerbolt valve covers that I have. Of all the centerbolt wire looms that I have come across none seem to work. Anyone have these valve covers with a wire loom set.
Attached Thumbnails Spark Plug Wire Looms with Centerbolt Valve Covers-centerbolt2.jpg
Old Apr 22, 2014 | 09:11 PM
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Transmission: 700R4(blown)
Axle/Gears: 3:73
http://www.billetspecialties.com/wir...l-bracket-kit/
I have these for sale never mounted just sat in my room on my coffee table. I have the flame pattern on em PM me if you are interested in them.
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
apo_bailon15
Mar 28, 2016 05:20 AM
db057
Aug 22, 2015 08:17 PM
