I Can just Siamese the upper plenum/runners right?
Old Apr 23, 2014 | 08:51 PM
mjdavis68's Avatar
Car: 88 IROC Z/28-under re-construction
Engine: 5.7 Tuned Port
Transmission: It's in there....
Axle/Gears: 9 bolt Borg-Warner
If i do the this is it worth a little throttle response? and do i just trim the gaskets too?
Old Apr 23, 2014 | 10:20 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
Re: I Can just Siamese the upper plenum/runners right?
I'm not sure about the throttle response, but you definitely want to match the gaskets to your new port shape. Otherwise you just wasted all the time & effort to siamese them as the gasket will be blocking airflow at best. At worst, you run the risk of sucking pieces of gasket into your engine.
Old Apr 24, 2014 | 08:59 PM
mjdavis68's Avatar
understand that, so i can just do the upper plenum and runners and trim the gaskets then..
Old Apr 24, 2014 | 09:19 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Just use a new razor blade to trim it to match the ports. I'd do the manifold ports too if you can remove it from the engine. You won't see as much benefit just doing to top side.
sheachopper
Jul 31, 2019 11:27 AM
Ed1LE
Sep 30, 2018 09:14 AM
MrPackstin
Oct 25, 2017 08:09 PM
loud91rs
Oct 5, 2015 10:05 PM
dbrochard
Interior Parts Wanted
Sep 28, 2015 07:40 PM
