fuel pump or fpr?
Old May 10, 2014 | 12:59 PM
nr2180's Avatar
Car: 91 Z28
Engine: L98 TPI
Transmission: 700R4 Transgo 2-3
Axle/Gears: 10 bolt 4.10s
fuel pump or fpr?
I have a quick question. When my car has set for a while I have to turn the key on and of a few times to prime the fuel system. The longer it sits the more I have to prime it. After it starts it will run like crap for a few minutes but then it runs ok. I tried to check my pressure with an Autozone fuel pressure checker. I got nothing on the gauge until I turned the key back and forth a few time and then it only read 18 psi. After I started it it stayed at 18 psi. Idk how much I would trust the gauge. I don't think 18 is enough for it to even run. I just put a new filter in and my injectors are fairly new. I replaced most of my vacuum lines(couple were dry rotted). So that leads me to believe the pump is weak and bleeding off or my fpr is shot. I pulled the vacuum line on the fpr while it was running and no gas came out. I don't have any gas in my oil. It is on a L98. So my question is do you think it is the pump or the fpr?
Old May 10, 2014 | 05:33 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: fuel pump or fpr?
Originally Posted by nr2180
I have a quick question. ?
https://www.thirdgen.org/forums/tech...formation.html
Old May 10, 2014 | 05:39 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Have to run the FPR leakdown tests to determine
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
