Really need some Fuel Pump help
Car: 92 camaro Z28
Engine: 350 tpi 5.7L
Ok. Motor was rebuilt about 2 mounths ago. Fuel pump had started going out before the rebuild. So we replaced it a couple days after fist cranking the car. But since then I have gone through 4 pumps they last about 2 weeks then the car starts cutting out when accelerating. Have tried two differnent brands and two different stores. I have checked the fuel pressure regulator it doesn't seem to have a problem. Vent from tank is good. Really need some help can't keep changing it out.
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Re: Really need some Fuel Pump help
Repeated failures after a short time period of different brands of pumps is no coincidence, something else is going on. Obviously after each pump change the problem is solved for 2 weeks so the problem is definitely causing the pumps to go bad.
Is the tank clean? Do you have the sock on the pump correctly? Are you still using the pulsator?
Car: 1984 Z28 HO
Are you replacing fuel filters also? If you are can you cut one open? If it's full, tank could be rusting out.
Car: 92 25th Anniversary RS
Engine: 5.0 TBI 305
Fuel filter may be causing it. If the filter is clogged, the pump may be burning out from working too hard.
Car: 92 camaro Z28
The tank was cleaned the first time and has been clean every other time. I replaced the fuel filter twice and it never seems to have any dirty gas in it. We took the pulsator out when the second pump went out and put some fuel hose as a bypass. But this last pump came with new rubber pieces so we put it back in.
Engine: 5.0 TBI 305
Car: 1987 iroc
Engine: 383 TPIS intake, Dyno Don headers
Transmission: 700R4 w/Pro-built Auto/transgo 2-3
Axle/Gears: 3.27/3.70 borg warner 9 bolt
I'm just curious as to what 2 brands you tried? Are they cheaper than a quality brand? Is the HP on your new rebuild under 400HP? Maybe a partial pinched or kinked line making the pump work harder?
Car: 92 camaro Z28
I had two airtex (I know they suck didn,t want to order one) and two delphi. The HP is still under 400. I will try and follow the fuel lines to look for kinks.
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
theres your problem.airtex and Delphi pumps come from china.which means there junk right out of the box.i have personally seen this happen with them .go to NAPA and get their best pump.i put one in my TPI car 5 years ago and have no problems
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
