no power steering?
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
no power steering?
When I am driving my car, there is no assist from the power steering. I just switched to serpentine set up and installed a u joint steering shaft. The pump does not leak or make any noises. Should I be looking for a bad pump, something with the steering shaft, or possibly air in the pump?
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
Re: no power steering?
Car: 85 Iroc-Z
I used the correct serpentine power steering pump. The fluid level is full too.
PS pump always turns CW; doesn't matter which belt style.
Sounds like the pump you have is fornicated somehow.
Car: 72 nova/ 90 camaro rs,04 suburban
Engine: blown 327/ 355/306/355/5.3
Transmission: muncie 4 speed/T5/powerglide,4l80e
Axle/Gears: 342/411/456/ moser axles
take belt off and see if you can pull the pulley away from pump, I have seen the shafts break and will turn pulley but not the pump
Squeaky8791
Feb 5, 2020 08:29 PM
Chuck84TA
Jul 15, 2016 09:05 PM
evilstuie
Apr 14, 2016 08:52 PM
